dkerber
I've been bitten by this before, but generally caught it. Last night I didn't, and lost an hour of data.
On my T3i (600D), if the settings wheel is set to Manual, BYE shows that, as it it should. But it also allows me to select Bulb mode in my Imaging settings, when that won't actually work. So what I ended up getting were 5 second exposures (the previous setting I had used on the camera), spaced 300 seconds apart (the setting I had set in the Imaging dialog). Not a very efficient way of gathering photons!! If I had caught it like I usually do, I could have switched to Bulb mode on the camera body and all would have been good. The reason I didn't catch it was that I was using a narrow band filter for the first time, and knew it would be darker than normal, so I just thought it was the filter that caused me to need such long exposures...
I realize this is just asking for an idiot check in the software, but if it's not too difficult to code, it would be a nice enhancement to either disallow bulb settings in the dialog when the dial is set to "M" on that model camera, or give a warning that my settings are contradictory...
Jan 9
11
Jan 7
5
Jan 23
admin 5 posts
s3igell 1 post
astroman133 2 posts
dkerber 8 posts
Jan 9 2020
Jan 7 2020
Jan 23 2020
17 answers to this question
