jayta98
So i have a T5i and I decided to use the planetary section on BYEOS since it is the only camera i got. I do see when I start capturing the best FPS i'm getting is 8.3. My laptop is old, it is a toshiba satellite Intel centrino dual core, 2 GB RAM and 500 GB SSD. Could the older laptop slowing down FPS? or Could it be some setting in the camera? I haven't changed much of the factory settings. Thanks.
8
6
Mar 5
15
Mar 2
6
Aug 6
5
Mar 14
jayta98 11 posts
admin 8 posts
astroman133 6 posts
lloyd75 4 posts
Mar 5 2016
Mar 2 2016
Aug 6 2018
Mar 14 2016
s3igell
Are you sure that you have a T5i instead of a T4i?? The T4i had significant Throughput Issues (USB / SD Card / other). The T5i came out quickly thereafter in order to replace it. If it is a T5i
admin
This is an issue with all T4i. They can not produce more than 9 or 10 fps. The T5i should do in the high teens, low twenties.
lloyd75
Hi there. I found the same issue using iCap and a planetary “webcam” type camera in Parallels, and that camera also yielded normal frame rates in a Mac native application. My guess is that the Paralle
38 answers to this question
