admin
BackyardEOS and BackyardNIKON support 3 providers for displaying the ambient temperature, humidity, and dew point.
Follow the instructions below to configure your weather center provider.
1) TEMPerHUM
A TEMPerHUM device sells for about $20 on eBay; BackyardEOS supports TEMPerHUM versions 1 and 2.
1. Plug the TEMPerHUM device in a USB port.
You do not need to install the drivers that came with it.
2. In BackyardEOS, open the Settings dialog and set the Weather Provider to ‘TEMPerHUM’ or ‘Auto detect’.
3. Click the Save button to close the settings window.
2) Yahoo RSS feed
1. Open your browser and go to http://weather.yahoo.com.
2. Enter your location and hit enter.
3. Look in the URL address bar; the numbers at the end is what yahoo calls a WOEID (Where On Earth ID).
4. In BackyardEOS, open the Settings dialog and set the Weather Provider to ‘Yahoo’ and enter the WOEID in the Yahoo WOEID field.
5. Click the Save button to close the settings window.
Here is an example (in this case the WOEID is 24002902)
http://weather.yahoo.com/canada/ontario/clarence-creek-24002902
NOTICE: Yahoo has made breaking changes to their API in February 2016. As a result BYE/BYN is no longer able to provide Yahoo as a weather source. This feature is be removed in a future release
3) Text File Delimited
1. Open the Settings dialog and set the Weather Provider to ‘Text File Delimited’ or ‘Auto detect’.
2. Click on ‘Text File Mapping”
3. Select a text file containing the weather information. BackyardEOS will read the last line only! This allows for cumulative weather information in the same file over time.
4. Enter the start position of each field and the number of characters to read from the start position. The reading box will show the result instantly.
5. There is no reading required for dew point. This is because the dew point is calculated from the temperature and humidity level.
6. Select the readout unit in the file; Fahrenheit or Celsius.
7. Click the Save button to close the settings window.
May 2
10
Dec 5
Dec 6
Feb 12
admin 11 posts
AaronSmall 3 posts
s3igell 4 posts
astroman133 7 posts
May 2 2016
Dec 5 2018
Dec 6 2018
Feb 12 2016
s3igell
In addition to using all the resources which Guylain and Rick responded with above, I've always resorted to the following Localized Tools: "Licked Finger" and "Tossed Sand" (No Grass Blades in the AZ
admin
BackyardEOS and BackyardNIKON support 3 providers for displaying the ambient temperature, humidity, and dew point. Follow the instructions below to configure your weather center provider. 1) T
s3igell
This is usually a sign of lingering issues with Security Permissions on your Win10 Installation (possibly due to something about how your User was configured before the Win10 Upgrade was performed).
35 answers to this question
