3.2.1 RC2 not saving settings
dkerber
I am setting up a new machine, and my installation of 3.2.1 RC2 works fine, and the settings work, but they're not being saved. So the next time I restart, everything is back to default settings.
I have uninstalled and reinstalled it with a reboot between, but it's still not saving settings.
Any ideas?
1 hour ago, astroman133 said:
I am in the Administrators group which has Full Control over the folder where BYE is installed.
In addition, the settings are saved with BYE 3.2.0, but not with 3.2.1 RC3 which is installed in a different folder.
I'm also an administrator on my PC and I had to change the permission and give write access to "users".  This is by no means a permanent solution, but a workaround.  I'd be interested to see if it works with write access granted to "users".
4 minutes ago, astroman133 said:
However,  for BYE 3.2.0, Users does not have Modify permission on its installation folder, but it works anyway.
Agreed, it's a hit-and-miss... one of these days I'll just have to bite the bullet and change the entire settings sub-system.  In the meantime this is a good workaround.
It does work! The one I had tried earlier was giving full control to the icon, which didn't help. Changing the permissions on the install directory as listed above did the trick!
Guylain,
I also noticed this not saving issue in BYE.  Hadn't worried about it as I only have a few settings different from the defaults, but it was mildly annoying.  I was also tweaking other things with my rig and the weather has been awful.  Unfortunately, it looks like it is time to update the settings sub-system.   The workaround does work.
You can blame my old college roommate who works at MS.  He must have found out I use BYE and is just messing with me.  Sorry, my friend.
BTW, I realized I'd been using your software for 10 years now.  Where did the time go?
Astroman133 et al: In reading through the entire thread, it is not clear what the "actually works" solution is.  Some work, some don't.  Can someone please list the steps (with illustrations, if possible) that are known to reliably and consistently SAVE Setting updates until the user/owner wants them changed again?  IMHO, without this, the value of BY EOS is diminished.  Better yet would be a YouTube video.  Also, the problem I have with Settings is for BY EOS 3.1 Premium.  The DSLR is a Canon T3i.
Edited by nahrstedt
Defines equipment and S/W version
i am having the same issue , the system not savinf setting changes. I have uninstalled, reinstalled and change permission as Admin suggested and still the same problem.
Im on windows 10, can someone help with a step by step solution? Thanks
