c22sail.REMOVEME
When I photograph an object in the sky my camera is orientated on the telescope such that it is viewing the object in landscape mode. As BYN goes through the set the light frames all show up in the thumbnails and on the screen in landscape mode.
Following the light frames I immediately and without changing anything record flats, bias, and dark frames. They also appear in the thumbnails and preview screen in landscape mode.
When I close BYN and go to the directory to load the images to PixInSight the lights are still in landscape mode but every calibration frame (flats, bias, darks) is in portrait mode. They have all been rotated 90 degrees clockwise. I figured out the rotation was clockwise by looking at the dust bunnies on the flat frames.
This occurs in every set I have taken and I haven't been able to work out the answer. It is easy enough to rotate the master calibration frames counter clockwise before stacking them with the light frames but there should be a reason this is happening. Any ideas?
Dec 15
Dec 14
Dec 22
Jul 26
c22sail.REMOVEME 5 posts
Ron Hillstromb 2 posts
astroman133 2 posts
tzaranek 1 post
Dec 15 2017
Dec 14 2017
Dec 22 2017
Jul 26 2020
1 post
Ron Hillstromb
OK I found the post but forgot the title that helped me. It is in the BYE Forum tthe title reads something like "Why are the images horizontal at times and vertical at times". First, I only have Can
c22sail.REMOVEME
I believe I have finally came across the solution. In this instance it is two fold. In my D810 I had "Rotate Tall" turned off. It turns out this is only for display. Another setting "Auto Rotation" wa
Ron Hillstromb
I had this problem with my Canon 60Da and other Canons in PixInsight. The problem was a setting in PixInsite and is related to the Raw conversionsoftware used. I don't remember the subject where the
10 answers to this question
