Focus Problem - Frame and Focus
JTWaters
What's the best way to focus my Canon 6D when no stars are displayed in 'Frame and Focus'?  There are no bright stars to focus on.  The lens are already set to infinity.  What's the ISO setting of the camera during Frame and Focus?
Jim
Phoenix, AZ
  • Answers 5
5 answers to this question
Jim,
The ISO setting is either what you have set it to be or the maximum value of the camera, depending on whether you have chosen to use "Maximum Sensitivity" setting.
With many lenses, infinite focus is not at the end of the focuser travel. It is back from it a bit.
The small size of the stars with a short focal length lens and the short exposure of LiveView frames make it very difficult, if not impossible, to focus a lens with LiveView. I would suggest taking short Snap exposures and use them to gauge how well you are focused. You can select a star and calculate the FWHM or HFD of it with short still frames, as well as with LiveView.
In most cases, you'll need to forget the idea of Focusing on Dim Stars around your chosen DSO Target.
You should Slew to a Bright Star (but avoid any near the Horizon - and avoid any of the Hyper-Giant Stars like Beetlegeuse or any Close Binaries as all will make Focus Difficult), perform your Best Focus, and then Slew to your Target for Framing.  THis will also give you the best chance of Framing using the Dimer but now In-Focus Stars of your Target FOV.
And Don't Forget:  Reset ISO to your desired Imaging ISO when returning to Imaging from Frame&Focus.
Jim,
When using a camera lens, instead of a telescope, you may have a problem even seeing a very bright star in LiveView.
Also, BYE and the Canon SDK allow you to change the exposure and ISO in LiveView. However neither of these affect the LiveView frame rate. So take short (5-10 second) snap images for focusing. This is the technique that you would have to use with a CCD camera. It works just fine. It is however somewhat slower than using LiveView.
