strikele
I have been testing my 500D inside as I just changed the power cable and wanted to ensure everything is working properly. I had had issues with my 500D in November and these seemed to be fixed in version 3.02, but I have not had the clear skies to test out in the field. Unfortunately today with both ver 3.02 and 3.03, I have run into download times of 3-6 minutes per image, both with 1/10 sec TV images and 45 second Bulb images. I have tried two different camera to computer cables, as well as running each of these cables both directly to the computer and through a powered hub with the same issue in each instance.
Using EOS utility, the images show up almost instantaneously.
It is possible that I have a setting somewhere set incorrectly since it has been so long since I last used BYE.
Have any other 500D users had this issue?
12 answers to this question
