GerryDi
Hello,
I have been using BYEOS for sometime and am still have difficulty in using the "Frame & Focus" section. Problem is I cannot get an image on the computer screen or the LCD screen of the camera (EOS 70D). I have tried just about every camera setting to acquire an image, but with no luck. I have this issue if I'm using the camera/lens combination or the camera attached directly (prime focus) to the telescope. I end up taking numerous blind shots in order to see and image and in focus, and that is not working very well.
Any and all help suggestions would be greatly appreciated.
Thank you,
Gerry Di
Oct 29
Oct 30
s3igell 1 post
astroman133 1 post
GerryDi 1 post
Oct 29 2019
Oct 30 2019
1 post
astroman133
Live View exposures are very short, on the order of 10 milliseconds long. Only the brightest stars will show up at all at prime focus. BYE has a Maximum Sensitivity setting. Be sure to select tha
s3igell
Frame&Focus is based on the same LiveView video feed as you see on the back LCD of the Camera (only displayed on a significantly larger screen). You can base your expectations on what you see
