coles44
I am setting up to capture the eclipse this Sunday. I want to bracket the exposures leading up to totality and at totality using the Capture Plan function. The strategy is to use one ISO and vary the exposure time. The problem is, I don't see how to set the exposure to less than 1 sec. I must be missing something obvious.
Al;so I want to repeat these plans over and over, with a set interval between each bracketed group of exposures. What is the best way to do that?
Thanks in advance.
Eric
Jan 16
Jan 17
admin 1 post
s3igell 1 post
astroman133 2 posts
coles44 2 posts
Jan 16 2019
Jan 17 2019
astroman133
I'm not sure what you are asking. The Loop button causes the entire capture plan to repeat. If you set the Delay time, it only delays the first execution of the plan. it does not delay subse
5 answers to this question
