skycamper
Ive made some progress being able to get two cameras connected. The goal is duel capturing same datat and info. Im trying to double my integration times for astrophotography. During bench testing on my couch , D5300 cameras, No usb hubs, no lenses, caps on bodies, both set on RAW same settings. Per the BYN directions I put the camera 2 shortcut on my desk top and used that to open a 2nd BYN screen. Was that ok?
Does Duel camera need to be checked in both master and slave BYN screens? in 1502 instance I assume is slave if I click duel camera it takes me to the screen that shows the extra cameras. I thought 1502 IS the extra camera? Im confused.
Will the slave follow what the master is doing? Do I need to input the ISO capture details in the slave 1502 camera? If I want the slave to do everything the master is doing then why can I make the slaves capture plan different on the 1502 camera??
I tried and failed to get both cameras to fire at the same time. There were some time outs as well. Maybe these log files will show what I did wrong.
Thanks
logfile-[20180323-15h02m14s530]-[8076]-2018-03-23.txt
logfile-[20180323-15h03m01s360]-[7600]-2018-03-23.txt
logfile-[20180323-15h14m23s562]-[10500]-2018-03-23.txt
9
7
Apr 1
10
Mar 23
8
Mar 24
6
Mar 25
skycamper 17 posts
admin 9 posts
astroman133 7 posts
Apr 1 2018
Mar 23 2018
Mar 24 2018
Mar 25 2018
admin
Did you read the manual? Does Duel camera need to be checked in both master and slave BYN screens? NO Will the slave follow what the master is doing? YES, that is the purpose. Do I ne
astroman133
I think that your questions can all be answered by carefully reading the manual. >> Per the BYN directions I put the camera 2 shortcut on my desk top and used that to open a 2nd BYN screen.
astroman133
It should. After both Camera1 and Camera2 are running, do they both show up in the Windows Task Manager? Have you connected both instances to their respective cameras? Without selecting
32 answers to this question
