Astrotortilla
bruno
Hi I cannot connect to astrotortilla, I have enabled the 3rd party & switched eos utility off as that also wouldn't let me connect to BYE, I have also switched the firewall off to check if that is stopping it & i have downloaded the latest BYE.
I have tried AT with my QHY5 and it works OK & also solves using images from my files, Any suggestions as i,m struggling atm
Andy
  • Answers 4
49 minutes ago, bruno said:
I have enabled 3rd party & checked that the port number is the same, Also when i apply settings & restart my computer it only lasts for that session i have to go through the same routine everytime i start BYE.
This has been reported over a dozen times already.  It's a Windows security issue caused by a Windows update.  Your only recourse is to re-install in a new folder; this will cause Windows to apply the correct security profile to the install folder.
Andy,
Once you enable the 3rd Party Integration in BYE you must exit and re-start BYE in order for it to take effect.
Also, you need to be sure that the same TCP port number is used in the BackyardEOS Camera Setup dialog in AT, and in the 3rd Party Integration settings in BYE. The default port is 1499. I would not change this on either side without a good reason.
Other things i have tried turning off anti virus & firewall to no avail, I've also reinstalled Astrotortilla with latest version, another thing was to turn off eos utility as that was conflicting with the connection of BYE.
On Another note all the other options on AT show that they are idle except BYE which shows error.
Thanks Andy
