Kevinwalsh
I bought a Losmandy mount last year and put it on a permanent pier (no shed; I use a cover), and for the past year and a half I've had to run 2 long USB cables from the BeeLink computer in my 'warm room' out to the mount and to the powered USB hub that the guide camera, DSLRs and ASI EAF focuser connect to.
I'm trying to simplify my set-up and take-down process at the beginning and end of each observing session. So I'm wondering if there a way to use a wifi connection to control my scope and not have to run the long USB cables. I've been able to use a wifi router to have my computer 'talk' to the Gemini 2 that controls the Losmandy mount. I plugged a USB cable from the hub into the wifi router, but I can't seem to get the computer to 'see' the hub or to 'talk' to any of the components plugged into the hub.
As an alternative to the wifi router and hub, I was wondering if the ASI AIR would essentially combine both operations - a wifi connection to my computer along with the USB connections needed for my cameras, etc.
Has anyone used an ASI AIR like this, and would I still be able to use BYE/BYN to control my Nikon and Canon cameras? I'm reluctant to spend two or three hundred dollars on an ASI AIR and then find out it won't do what I want. I have not found anything via these forums or the interwebz that shows anyone using BYE/BYN via the ASI AIR.
Thanks for any comments, suggestions, and help.
Kevin
Aug 16
Aug 19
Aug 17
Kevinwalsh 2 posts
admin 1 post
s3igell 1 post
astroman133 1 post
Aug 16 2025
Aug 19 2025
1 post
Aug 17 2025
1 post
