FERRAN_BOSCH
Hi again, when capturing the flats, is it necessary to turn the camera dial to the AV position, or is it not necessary?
Thanks so much.
Dec 10
Dec 11
Dec 12
FERRAN_BOSCH 4 posts
admin 1 post
s3igell 1 post
astroman133 1 post
Dec 10 2023
Dec 11 2023
Dec 12 2023
1 post
s3igell
Remember, for Flats you need to keep the same Aperture as you shot the Lights. Otherwise, the change in Aperture will effect the Vignetting - voiding one of the main purposes for the Flats.
astroman133
If you try to capture an image with the shooting mode set to M and the Shutter value in BYE set to AV-Flat, BYE will complain that the shooting mode must be set to Av. In Av mode, the aperture is
FERRAN_BOSCH
I know, if you connect the DSLR to a telescope, you can hardly change the focal length, it's a different matter if you change the focal length of a lens, but on a telescope you can't change it easily
6 answers to this question
