rbguppy
Windows 11 on Mele Quieter 3Q
USB Cable is data only, not charging
Backyard EOS 3.2.3 Classic Edition (Tried both Camera 1 and Camera 2)
On the R6 I selected “Choose USB connection app” as “Photo Import/Remote Control”
When connected and powered the Camera image mounts with the drives on left side labelled “Canon EOS R6m2” and I can expand it to show the two SD cards marked “SD1” and “SD2”. I tried to prevent the mounting through admin commands at the Terminal but they still mount when the Camera gets connected. Also the camera’s flip screen displays the remaining battery life (horizontally) and an image of a PC below that.
When I start up BYE can select “connect” on the image of the camera it then prompts for the for the proper DIGIC models which I select as the topmost (after 2008).And the proper screen comes up for a moment and then disappears. The log states:
“EOS-R6MkII CONNECTED”
“Camera SHUTDOWN”. Which occurs one second later.
Attempted one more time with the same result. Tried waiting for camera to rest and insert more charged batteries but same thing happens!
The next time I attempted the BYE went bye and terminated. I restarted the software and it repeated the fail of the software.And again so I shut everything down. Restarted and now it just says connection problems? “Camera Not Found! Make sure it’s connected to the PC….
While the BYE is negotiating with the R6 the camera flip screen is restored to the usual view with shooting data.
Thanks for any assistance!
May 22
May 20
May 21
astroman133 2 posts
rbguppy 2 posts
admin 1 post
s3igell 1 post
May 22 2023
May 20 2023
May 21 2023
5 answers to this question
