catherineryanhyde
I'm Using BYN Premium 2.1.2 with a D810A. For some time now I've been having a problem with download timeouts cancelling sessions. Someone on this forum suggested it might be the data cable, which is possible. But now I have two more unexplained errors. Twice in the past few days it has stopped after a download, but rather than the log reporting the error, it says the session finished successfully. But it took maybe three images and I can clearly see it was set to take nine or ten. Then, three times in the last two nights it has gotten a third or halfway through a sequence/session and cancelled itself, and the explanation the log gives is that I need to check to be sure the camera is set to M. Of course that makes no sense because it just took a bunch of images before canceling, and nobody snuck out there and changed any settings. I have another setup that runs a different telescope and mount. Same camera model, same version of BYN, and I'm not getting these errors on it. I don't know if that means the problem is in the camera, or if the software became corrupted somehow on the one computer. I'd be grateful for any ideas. Thanks.
Jan 2
11
Jan 3
Jan 4
admin 4 posts
astroman133 4 posts
catherineryanhyde 8 posts
Jan 2 2022
Jan 3 2022
Jan 4 2022
1 post
catherineryanhyde
for the USB connection, I've replaced the cables multiple times, and I'm using those plastic... no idea what you call them... that clip around the connection on the camera end and pin it into place. S
astroman133
Yes, Windows Defender is part of Windows 10, but I don't know whether it is automatically activated or not.
15 answers to this question
