acatalano
I am using BYN V 2.1.1 RC3 together with ASTAP to platesolve. I also use Cartes du Ciel as my planetarium program. It has been a great relief to finally get platesolving to work after the frustrating experience using Astrotortilla. However most recently,and for reasons I do not understand I am getting "Access Violation OK to ignore and risk data corruption or Abort to Kill". CDC is communicating perfectly with BYN and importing coordinates, but when I go to platesolve, after a short time a window pops up from ASTAP that seems to indicate it is searching within a 180 degree range and the number of degress is rapidly decreasing until around 55 degrees or so (notthe same value each time) the Access Violation! window pops up and ASTAP halts. In thepast I have clicked OK to proceed and the program has moved ahead, but most of the times after freezing I need to restart BYN. I'm wondering if there is anyone else experiencing this and if there is a known cause/solution.
Dec 18
Dec 17
admin 2 posts
astroman133 1 post
acatalano 2 posts
Dec 18 2020
Dec 17 2020
