Problem during shooting
Francesco_Masi
Hello All, I apologize for English but I use google translator.
I own Nikon Backyard software, I have a problem: (I state that I have updated my Nikon D810 to the latest firmware) I connect the machine and everything is ok, I try to focus and everything is ok , when I go to take the photograph, it seems as if it does not store the photograph on the PC because the program remains to "think" when the photograph has already been taken. How can I solve the problem? Many thanks all in advance
  • Answers 36
Is there a problem converting a numeric string to an Int32 because of the Windows culture setting?
He also has the MirrorLock time to 4 seconds. See the excerpt from the very long log file:
2020-07-09 22:17:20,001 [CameraTakePictureOnMessageRecieved] INFO  - CameraPropertyChangedArgs fired: MirrorLock           = '4'
2020-07-09 22:17:20,009 [7] DEBUG - TAKE PICTURE ::: Shutter(MANUAL) Cable(CameraUSB) Av(2.8) Duration(2,0) Iso(Hi-2.0) Quality(JPEG Fine) Mirror(0) SaveTo(PC)
2020-07-09 22:17:20,523 [7] DEBUG - Device Busy trying to start picture sequence
2020-07-09 22:17:20,526 [7] ERROR - [kNkMAIDResult_NotSupported] (kNkMAIDCommand_CapStart, 17, kNkMAIDDataType_Null, 0)
2020-07-09 22:17:20,526 [7] ERROR -    in BinaryRivers.Camera.Nikon.Wrapper.NikonTaskQueue.Invoke(Delegate d, Object[] args)
   in BinaryRivers.Camera.Nikon.Wrapper.NikonBase.Start(eNkMAIDCapability cap, eNkMAIDDataType dataType, Int32 data)
   in BinaryRivers.Camera.Nikon.Wrapper.NikonDevice.Capture()
   in BinaryRivers.Camera.Nikon.CameraModel.<>c__DisplayClass27_0.<DoTakePicture>b__0()
   in BinaryRivers.Common.ProviderInterfaces.Camera.CameraControllerBase.DoWithCameraLocked(Action action)
   in BinaryRivers.Camera.Nikon.CameraModel.DoTakePicture(Single mirrorlockseconds)
   in BinaryRivers.Common.Model.CameraModelBase.<>c__DisplayClass81_0.<TakePicture>b__0(Object state)
2020-07-09 22:17:22,580 [CameraTakePictureOnMessageRecieved] ERROR - Formato della stringa di input non corretto.
2020-07-09 22:17:22,580 [CameraTakePictureOnMessageRecieved] ERROR -    in System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   in System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
   in System.Convert.ToInt32(String value)
   in BinaryRivers.Common.Extensions.StringExtensions.ConvertToInt32(String int32String, Int32 defaultvalue, Boolean verbose)
Thanks Rick.  I did not see the mirror lock. That is probably the root cause.
3 hours ago, astroman133 said:
Francesco,
Please reset the Mirror Lock delay time to 0. BYN does not support MirrorLock and this could be causing the issue. In BYN 2.1, you can hide the MirrorLock control via the Advanced Settings.
YEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEESSSSSSSSSSSSSSS IT'S WORKKKK, the problem was the Mirror Lock!!!! THANKS A LOOOT ALL
