jcbeyer
BackyardNIKON v2.0.11
Nikon D800E
Astro-physics Mach 1 Mount with APCC-Pro
I dithered without guiding for about 6 hours over the past several days, dithering was every 3 frames and had no problems at all.
Last night, imaging started 10:33, 50 second exposures, dithering every 3rd exposure. The system worked fine until 11:59 when a command for a dither was sent and the RA axis moved a long distance almost moving the target out of frame and never moving back. It stayed in that location through the next exposure. I recentered the target and continued. BYN continued to indicate that dithers were being sent to the mount, however, there was no movement or indication the mount received the command - I confirmed the mount was connected to BYN. Parked the telescope and re-slewed to the target. Restarted the series, but with each dither afterwards the RA axis would move approximately 10-15 degrees west then return to approximately the same location. The final movement after the long travel was approximately the distance a normal dither would produce. Terminated that sequence.
Parked telescope and restarted BYN and APCC-Pro. Slewed to a different target to test. I took a series of about 10 exposures with dithering and all seemed to work normally.
Let me know if you'd like the log from the computer.
Joe
6
May 27
5
Jun 4
5
May 28
admin 6 posts
jcbeyer 6 posts
astroman133 2 posts
May 27 2020
Jun 4 2020
May 28 2020
13 answers to this question
