aamiet
Hi there, I have the Classic version of BYEOS 3.1.17 and I've noticed that when I connect by 700D to my laptop computer running on mains power, I can get around 20fps running in Planetary mode (fairly standard). However, when I run on battery power, the fps rate drops to around 17 fps. I've changed the power settings so the cpu runs at 100% on battery power, and all the others setting I could find to match when running on power, everything I can think of really to no effect. Have you noticed this before, and how can I fix it?
Also, it would be really great to get a histogram view in planetary mode, just so I could check to see if I am using the best ISO/shutter speed for optimum results.
Thanks,
Andrew
Apr 6
admin 1 post
astroman133 1 post
aamiet 2 posts
Apr 6 2019
3 answers to this question
