D40x Not Connecting
deansj
Condition: Camera not connecting:
  • Nikon D40x, fully charged, few file on SD card
  • Direct USB cable connection to PC working – indicated by other capture software
  • USB mode set to MTP/PTP (not mass storage)
  • Windows 10 on ASUS running on AMD chipset
  • Connection attempt times out (never ends – need to kill BYN)
  • Other compatibility options tested and failed.  Elevated privileges used, same result.
 Sample Log using XP SP3 compatibility test mode:
 Nikon 2015 selected, followed by D40x selection
 11:25:55  Licensed to deansj
11:27:05  Attempting to connect camera...
11:27:05  Nikon2015/D40X drivers initialized.
11:27:12  Camera Not Found!  Make sure it's connected to the PC and turned ON :)
Following one test where the connection attempt just kept going, I killed the BYN and had this error:
(Screeny attached)
C++ Error.docx
  • Answers 7
7 answers to this question
C++ redistributable was installed, but required a repair.
Repair completed.  PC restarted.  BYN restarted.
Connection failed under Vista compatibility setting with this log:
12:41:44  Licensed to deansj
12:42:38  Attempting to connect camera...
12:42:38  Nikon2015/D40X drivers initialized.
12:42:46  Camera Not Found!  Make sure it's connected to the PC and turned ON :)
No C++ errors.
Are there further troubleshooting options?
Regards.
BYN 2.0.9 Trial version is being used.
For the D40x model (a great vintage :)) USB only two options.  The other is mass storage.  My understanding of that option is for access to SD card.
"When the camera is in the PTP (Picture Transfer Protocol) mode, it appears to the computer as a camera. As such, aside from basic file transfer tasks it allows you to remotely control the camera (fire the shutter, change exposure, etc.) as well as use various advanced features (custom curves, additional settings, etc.). Generally speaking most PTP drivers will also mount the camera's memory card, so you'll have all the functionality of MSC as well."
The above comment seems supported by my experience using DigiCameraContol.  No communications is possible to that software using Mass Storage" mode.
Regards
Trial complete.  Same result:
15:46:59  Licensed to deansj
15:47:26  Attempting to connect camera...
15:47:26  Nikon2015/D40X drivers initialized.
15:47:34  Camera Not Found!  Make sure it's connected to the PC and turned ON :)
I verified that the SD in the camera is indeed readable and therefore that I had a good cable connection.
HOWEVER!!  I have installed the same version on an old Intel CPU PC and have been able to connect.  I can verify that MTP/PTP is the correct USB mode - not Mass Storage.
That leaves me to attempt to find out what is different in PC's operating environment.  This may prove impossible of course.  If you have any areas for me to investigate, please share those.
I have a plan for evaluating the software now. If I like the software, I will buy a full license and a new Nikon D5300 with LiveView.
I appreciate your assistance.
I will try an install of the software onto another computer, to rule out any PC local issues.
