Can't change exposure in frame and focus
cuivenion
  • Answers 11
11 answers to this question
1 hour ago, cuivenion said:
Hi, I'm still having probelms with this. It's intermittant. When folder should I reininstall it to?
What does this mean "When folder should I reininstall it to?"?
Is the camera set to M?  If yes delete the cache.  See Settings -> Advance Settings.  Then restart the application and make sure the camera dial is set to M when you connect your camera.
On 02/02/2018 at 1:35 AM, astroman133 said:
I would suggest that you try "Delete Cache Data" on the Advanced Settings screen; then restart BYE.
If that does not work to give you a full list of exposures then I would install BYE to a different folder.
Hi, I was referring to this post. The dial is set to M and I have tried deleting the cache. It keeps happening.
