foremans
I have just starting using BYE 3.2.2 Premium (Canon 70D) and spent some time using Frame and Focus to help setup the telescope. I was able to do an eight minute bulb exposure. (file not saved)
It was working fine via USB. I have successfully used Canon Utility (2) and BYE was recommended by another Backyard user.
I have ensured that Canon Utility was closed before connecting to camera with BYE.
Connection works as I have said, using Frame & Focus but when I try to preview on Imaging I get the Error, "Your camera requires a configured serial cable for BULB and Mirror Lock."
I have tried another shorter cable (1.5m)
I tested turning the Mirror Lockup function on using the camera settings. When I attempt a preview now I note that the Mirror Lockup reverts to off on the BYE screen and in the camera. The system is talking to the camera.
I have successfully used this on another computer. The difference. Windows 10 vs Windows 11. I will see if it is a Canon driver issue (Canon Utility does work though) - if not then I would be happy to beta test any work you are doing towards getting this working on Windows 11.
Solution
Run BYE as Administrator on Windows 11! 😜.
Edited by foremansMore information from testing.
Jan 17
Jan 18
Jan 19
admin 3 posts
astroman133 1 post
foremans 3 posts
Jan 17 2022
Jan 18 2022
Jan 19 2022
6 answers to this question
