<scopera> and <scopedec>
dts350z
While setting up preferences for RC05 I noticed these file stamp options.
To get those to populate I just need to connect to my scope via ASCOM?
Those will be accurate even with dithering?
And, can I put them both in one "Name Item Number" (since I've already used 9) like this:
<scopera>scopera_<scopedec>scopedec_  ?
Oh, I see now the Filename Template editor says I can do that. Duh...
Thanks
  • Answers 8
8 answers to this question
There is text at the top of the editor that tells you you CAN put two on a line.
Putting two on a line is working, except the descripters are not where I put them. I put <parm1>descripter1_<param2>descripter2_ and I got:
descripter1_descripter2_<param1><param2>.
Look at the file name in the larger shot.
I'll check that.
Thanks
Those have been there for at least 1 year now, there were in 3.0.x.
Yes, these are the actual RA/DEC coordinates when the image was downloaded, before dithering, so they are the actual coordinate reported by the ASCOM Telescope driver as of the end of the exposure.
