D5200 + Astrotortilla Capture Fails
andromeda365
Hello
I thought it was best to open a separate thread by Its worth nothing this issue may be directly related to the other issue I just posted about exposure times not changing from what is set on the physical camera itself.
So I have the TCP server listening on the default port 1499 and Astro Tortilla appears to connect just fine.  When I click "Capture & Solve" in astro tortilla I can see it start to take a image but then error out.
This is the last ERROR from my log file which appears several times in the log file.
[kNkMAIDResult_UnexpectedError] (kNkMAIDCommand_CapGet, 33342, knkMAIDDataType_UnsignedPtr, 216131604)
I have tried to google this but not much comes up.
  • Answers 3
3 answers to this question
23 hours ago, admin said:
The 2 errors are related, BYN can't take exposures so taking exposures using AstroTortilla will also fail.
Please use the other thread you just created; once it is solved so will this issue :)
Regards.
You're 100% spot on.  Fixing the other issue solved this one.  I've got BYN and Astro Tortilla playing nicely together.  I can't wait to try some plate solving.  Thanks so much for you help.  Great product, great support!!
