D5200 Finding Camera
MrWellsy66
Hi
Loaded BackyardNikon and can't seem to find camera from computer. Connected DSUSB and camera cable back to USB, turned on camera, waited 10 seconds fired up BackyardNikon and waited for things to initialize and then attempted to connect to camera and it's not found, what might i be doing wrong ?
22:08:17  Camera Not Found!  Make sure it's connected to the PC and turned ON :)
Both cables connected and camera turned on battery full power and memory card out.
Thanks
Craig
  • Answers 12
12 answers to this question
Hi
Thanks
Craig
Try rebooting your computer, this should reset your windows/nikon drivers... which i think is the cause.
I re started computer and same thing camera not found
Craig
Thanks... but it used to connect, right?
No this was the first time i tried to connect after downloading BackyardNikon
Also tried a blank memory card and still no connecting to the camera.
Thanks
Craig
something I found works everytime in a particular order...Open PHD guiding,connect autoguider and mount...open BackyardNIKON,with all cables connected to camera,turn it on,if Nikon transfer opens,close it ,wait 10 sec.then connect camera...hope it works:)
Thanks Saltcod but i am not using for AP yet, no mount or PHD.
I can get DSLR Shutter to work but still unable to connect to BackyardNIKON
Craig
I have the same problem than yours with my D90 (Laptop Acer W8.1 x64).
I already asked for some advices on a French forum (WebAstro), and my doubt was on the USB cable extension I was using.
In fact, it is not the case.
I installed other software like "DCamCapture" & "DSLR Shutter" and it tooks about 3 mins before it starts.
Then I launched BYN and it works correctly !
I tried also on another computer W8.1 x32 : same problem.
I dowloaded an other software named DigiCamControl which is not directly dedicated for AP (I'm not sure that it can make Bulb control whith my D90, until I don't have SteveRoseNow cable...).
BUT with this soft : less than 2s to initiate my D90 !
After that, BYN found the D90 and I can discover some function very interesting like FWMH,...
Right now I'm not confident in BYN, I cannot prey each time I connect my D90 ...
If it can help...
Didier
If it can help...
Didier
Thanks SUNJiaLin
I tryed opening w/ DSLR Shutter then connecting with BackyardNIKON and still not able to connect to
BackyardNIKON. I have all software and firmware updated, battery fully charged, empty memory card in place, still not sure why i can't connect.
Thanks though
Craig
Is any one else using a D5200 ??
Just wanted to know if anyone else was or did have problems connecting to BackyardNikon ????
Thanks
See this post I made a few minutes ago.
Although not a D5200, the issue is the same I believe <_>
http://forum.otelescope.com/post/d5100-disconnected-after-4-hours-of-successful-imaging-6925740?pid=1283358408
