mestutters
Hi,
I am using PHD2 Log Viewer to examine a PHD2 log recorded recently while I was imaging with BYE. In the viewer it is possible to have highlighted sections of the log that relate to data points acquired while the mount is settling following a Dither command. It is possible in principle to identify the data points to be highlighted / ignored within Log Viewer either parametrically or by means of PHD2 Server API events recorded in the log by PHD2 Guiding provided that PHD2 Guiding is appropriately invoked by the calling application.
My understanding is that BYE does not used at present call PHD2 Guiding in Server mode so to exclude settle period data points it is necessary to set appropriate values for the two parameters 'Settle at < x.x pixels' and 'For yy seconds' in the PHD2 Log Viewer, under the Settings menu.
My questions are:
a) Should these two parameters be set exactly as the two parameters 'Settle dither at' and 'Calm down period' within the Dither Section of the BYE Settings Panel?
Thanks for an excellent application.
Best regards
Mike
3 answers to this question
