Mercury Transit - Solar Imaging with BYE and Canon 100D
mestutters
Hi,
I have not previously tried solar imaging but thought I would give it a trial in preparation for the forthcoming Mercury transit. My set-up is a 60mm triplet APO with Canon 100D, imaging through Baader Astro Solar film.
Through an eyepiece I am able to see faculae and a few sun-spots but when I try imaging I've not so far managed to capture any of this detail.
Do you have any recommendations / suggestions as to how to proceed in particular with regard to focusing and image capture - I have been trying to use Planetary mode with 5 x zoom.
I think the problem is that the Sun's brightness is washing out the surface details.
Thanks in advance
Mike
  • Answers 2
It sounds that most likely you are Right - you may well be Over-Exposing.
The Exposure Emulation Setting impacts the actual Exposure during LiveView.
You'll want to review several of the "Planetary Imaging" Threads posted on this Forum (Search... is in upper right).
Try ISO 100 and bring down the shutter speed, way down.  Try 1/100th second and then adjust accordingly.  You will find the sweet spot eventually.  It a trial and error process.
