ABPiecka
Guyroch, FYI
I have been trying to get the new release to work with no luck. I have downloaded it at least 6-8 times. I began deleting the old versions and all related files between each after about the 3rd time.When I try to download I get the following:
C:|Program files\backyardnikonv1.0\binaryrivers.backyardnikon.start.camers1.exc
error: while trying to replace the existing file Deletefile failed;code 5
access is denied
the option abort,retry,ignore are available. retry and ignore get nothing abort is the only option that works
when I tried to delete the BYN program files it is denied because of a file AForge.dll is in use
I finally got everything deleted and tried several more times and got the program to open only to not be able to connect to any of my cameras ( nikon 800, 800E, 7000) Tried several times connecting disconnecting restart etc
Deleted all the BYN files related to 1.0.5 again including the AForge.dll, loaded release 1.0.4 and it worked like a charm.
I'm up and running but am reluctant to try 1.0.5 again.
5 answers to this question
