Matthew
Hey folks,
A minor surprise I have found running two Canon 40Ds into two instances of BYE 3.1.5.
I turn on the first camera and select the Digic III / IV selector from the middle tab - all fine.
Then I start the second camera and second instance of BYE 3.1.5 and press connect selecting the same series driver.
Now it shows me two instances of Canon's - both on the same USB port 4519 - (they connect over a powered USB 2.0 / 3.0 hub). The top camera in the list is the one that is already connected to the first instance of BYE - the second camera in the list is the one I need to grab.
Once I connect to the second camera all is fine. Now if I hover the mouse over the two instance of BYE in the bottom of the screen along from the Windows7 start button each reports a different USB number. I am wondering if the logic that shows the ports versus the logic that names the running instances is named from the window's task id or the port id.
Having both cameras report the same USB port isn't too helpful.
Cheers,
Matthew
11 answers to this question
