Focussing stops working after taking a snap
jellison
Strange issue I'm seeing in version 3.2.3 with a Canon 5D mark II where the focussing buttons will stop working.  To reproduce:
1) Power on camera and connect BackyardEOS.
2) Select Frame and Focus to activate the live view.
3) Try the focussing buttons - they should work fine
4) Do Snap Image
5) Press one of the focus buttons
6) Press Live View
7) Focus buttons no longer work
If you omit step 5 the focus buttons keep working.
  • Answers 10
10 answers to this question
OK, I do not believe that the lens focus chevron buttons work when LiveView is paused. From your steps, step 6 should pause LiveView which means that the image on the BYE screenj is no longer updated so even if the chevron buttons cause the focus to change you would not see it until you resume LiveView.
Strange, thanks for looking anyway.  I'll attach the log file in case that helps.  Line 628 is my step 5 and then step 6 is line 629, after that the mouse focus clicks can be seen on lines 645 onwards but the camera is ignoring them.
I'll have more of a play with the camera settings as well, maybe I've stuffed something up in there without realising.
logfile-[20250109-22h31m32s329]-[14952]-2025-01-09.txt
You're not using the correct SDK/Drivers when connecting your 5D Mk 2.
2025-01-09 22:31:39,923 [Main] DEBUG - ButtonPlus_MouseClick(btnCam2 = 'DIGIC 2 cameras generally manufactured before 2008 (5D, 20D, 20Da, 30D, 350D)')
2025-01-09 22:31:39,932 [Main] INFO  - Attempting to connect camera...
2025-01-09 22:31:39,932 [Main] INFO  - Camera action fired: 'MaestroChoose'
2025-01-09 22:31:39,934 [Main] INFO  - Running (throw): EDSDK.EdsInitializeSDK()
2025-01-09 22:31:39,943 [Main] INFO  - Success: EDSDK.EdsInitializeSDK()
2025-01-09 22:31:39,943 [Main] INFO  - Running (throw): EDSDK.EdsSetCameraAddedHandler(_cameraAddedDelegate, IntPtr.Zero)
2025-01-09 22:31:39,955 [Main] INFO  - Success: EDSDK.EdsSetCameraAddedHandler(_cameraAddedDelegate, IntPtr.Zero)
2025-01-09 22:31:39,958 [Main] INFO  - Canon drivers 'Canon210\' initialized.
Please select the other option and try again. Keep us posted.
