rv97007
Hello!
I am using BYE on a Canon T2i.
I am trying to write a plan to use BYE for the eclipse. I composed and saved a plan, but notice that it does not save the "Duration" field.
The "Duration" field would be of great help in pausing between the rows, waiting between each phase of the eclipse.
I edited the file to manually enter "Duration=123", terminating with a "|", nested between Av and ISO fields. Upon loading this edited file, I notice that the durations are read and updated correctly in the UI, but are greyed out. Upon testing the plan, the duration is not used at all.
Experts, please let me know how to use the "Duration" setting correctly. Thank you!
Mar 30
Mar 31
rv97007 2 posts
admin 1 post
astroman133 1 post
Mar 30 2024
Mar 31 2024
1 post
astroman133
When the Shutter is set to BULB, Duration is the length of the camera-timed exposure. The value has units of minutes. There is an unlabeled column to the right of the Pause column. When you click
admin
Duration is for bulb only. Minimum is 1 seconds. Tv is more precise for sub second exposure.
3 answers to this question
