Astrophoche
I have been struggling to get BYE to save images with my Canon Xsi (450D). Back in the trial days, it worked fine near as I could tell, but I have a "new" computer and a licensed version of BYE and I can't get any images to save. I am using Windows 10 Pro build 19044.2965. Now I am using the BYE V3.2 (camera2) which I believe I was told would run independently from needing to run with the primary BYE instance. I just always use the 2nd instance with my Xsi out of habit. Camera is in the M mode for ALL scenarios. Camera running on AC or battery seems to make no difference. Camera FW 1.1.0
Two scenarios:
Scenario one: I diddled with the custom camera functions to provide live view, mirror up capability. I connected the XSI via USB with no issue. I could not see anything on the image display center. I tried taking a single frame, but I was having no luck getting pictures using the "imaging" function. Basically, the progress wheel states 13+ minutes to completion and after about 60 seconds the process times out with the General Camera error. No images presented or saved.
So I switched to Frame and focus and things seemed to get better. With "auto focus" ON the lens, I could see the live view image and adjust the focus just fine with the focus controls on BYE. Cool beans, I think. So I take a shot or two adjusting the F stop and exposure times. The live view image in the image display center changes with each parameter change (f and t) appropriately. So I take some shots but none load at the bottom of the Image display center. I look for them in the appropriate BYE folders and none are found. I look on the SD card separately, but nothing there either. When I click the Snap Image button, the camera clicks and whirs just like it's actually taking a picture, but none seem to show up anywhere. I get "Image session completed successfully" in the log. I also see images in the BYE temp folder deleted.
So I figure I set something up wrong and Clear ALL settings back to default.
Scenario 2: I do nothing to change any of the default settings in the camera. And I skip Imaging altogether. Go straight to Frame and focus. Nothing for live view. BYE keeps my old parameters for taking the picture and I click Snap Image. Well, the Image Display center now shows a resulting picture! Adjusting the F&T produces several different exposures but no thumbnails at the bottom of the Display Center. And sure enough, Nothing in the DCIM on the SD card either! Although I'm told the imaging session was successful each time.
I've included a couple of log files just in case they are useful.
I can disconnect the camera from the USB (and therefore BYE) and take pictures just fine. They show up on the SD card before or after the camera settings changes.
I am having no trouble with BYE v3.2 (primary instance) with my Canon R.
Suggestions?
logfile-[20230526-13h45m15s271]-[4460]-2023-05-26.txt logfile-[20230526-14h01m58s444]-[20220]-2023-05-26.txt
May 27
7
May 26
astroman133 4 posts
Astrophoche 4 posts
admin 1 post
May 27 2023
May 26 2023
Astrophoche
Thank you Astroman133 and Admin! It all now works! So first, I set the camera to RAW only and maximum stability per Admin's suggestion. I got nowhere until I went into the camera and all
8 answers to this question
