iiiRichard
I want to use my older canon Rebel 350d.  When I start up and connect... log will say Canon driver 210 initalized. Then Camera not found.
I also have a newer 5Ti  which will connect using the normal camera cable.  But I want to use the older camera since it has had the filter removed.
I am using windows 7. Canon tells me there are no driver for this older camera. In one of the posts dated Aug 2015 ... you need to select the 210 drivers in BYE.  When starting up the two selections are Old cameras or New cameras .
Help very much needed!!!
Richard
  • Answers 4
   I have an older laytip... ep .... if I can download a second copy BYE... I could try it on that computer.  I just got to contact some at BYE to see it that is ok.  But thanks for the bad news.
Yes, you can install in a second computer provided you only use one at a time; otherwise a second key is needed.  This information is also stated in the EULA.
