strikele
I am imaging with a 500D (T1i) camera and ran into a couple of issues with 3.1.4 last week. I had not imaged since August 2014, using 3.1.0, and had with no issues with that version at all.
The first issue last week was that the camera information window (and the display on the back of the camera) would not update to reflect the values, ISO, shutter speed, etc input in the capture plan area. Images were taken at the initial settings. This does seem to be an issue with the SDK since once I copied the Canon folder from 3.1.3 into 3.1.4, everything worked perfectly. Hopefully anyone else who runs into this issue will do the same until the issue is corrected.
The second issue, which also occurs in 3.1.3 and maybe back to 3.1.1, is that my file names are set up to include the temperature. This works fine for my lights and darks, but no temperature shows in the file name when I take a flat or bias (using TV mode). There is an error message in the log below at 2015-09-23 14:07:24,911 that may or may not be associated with the issue. No such error occurs when imaging lights. This unfortunately prevents me from temperature matching my biases in my bias library to my lights or flats.
Excerpt of log file:
2015-09-23 14:07:13,001 [4] INFO - Task 'ProcessCapture' was sent to server for processing, response was 'Queued for processing at 23/09/2015 2:07:13 PM'
5 answers to this question
