mcovington
I've probably overlooked something obvious... I'm doing an image sequence right now, and Progress Center is not on the screen; only the rotating dial at the upper right is the progress indicator. During the previous imaging sequence, Progress Center dominated the right-hand side of the screen, which was handy.
Also, Histogram Center has appeared, and I don't recall seeing it in the previous sequence.
I presume there are buttons that toggle the visibility of these, and I haven't recognized them...?
May 29
7
May 30
admin 2 posts
astroman133 2 posts
mcovington 5 posts
May 29 2022
May 30 2022
admin
Don't use netbook resolution, this will force the smallest window between application restart, and you'll get that behavior all the time.
mcovington
It was much, much simpler than that. On the Settings menu is a checkbox that turns Progress Center (big display) off. I had apparently hit it. The disappearance of Histogram Center does seem t
8 answers to this question
