Flats And Bias
mtzintexas
Two questions, how can I do bias frames I cannot see exposure times less than 1 second and under the shutter tab I only see bulb, av flat, and program?
Regarding flats, the AV flat selection under the shutter tab along with the AV selection on the camera itself should expose the flat correctly?  I understand that I can right click on an image to get image stats, what type of mean should I look for on my flats with that?
I am connected with a T3i in version 3.1.1 premium edition.
thanks for helping out a newbe
  • Answers 7
7 answers to this question
Guylain,
Any chance of putting a button that deletes the cache under the advanced settings tab?  The problem above (and the solution) seems to occur a lot for many users. I was thinking a button that clears the cache and then restarts BYE would allow for a quick and easy fix.  Since I'm not a programmer, I'm not sure what is involved so feel free to ignore the suggestion if this is too much of a PITA.
Aaron
