acatalano
So, I download the pre-release of BYN (2.1.1 RC3), installed ASTAP for plate solving, upgraded cygwin for Astrotortilla(AT), installed the SP1 of ASCOM 6.5 as suggested by the groups.io regarding At not working and actually had a moderately clear night where I could actually see windmills to tilt at! I had really no luck with AT at all, although my own ignorance may be to blame. Should I actually connect the mount in BYN as I did for ASTAP? It seemed to me that AT, when it worked, directly controlled the mount without invoking BYN. However again given my inexperience, perhaps that was the real reason AT has been failing all along. Just another "i" to dot.
Anyway, ASTAP was not without issues. I'll attach the log here in case it may help. I got error messages from time to time that Cartes du Ciel could not be reached, the mount was disconnected etc., but after I got used to the workflow, and restarted everything 2-3 times, everything seemed to work, with one exception. I could not get ASTAP to plate solve correctly for M31, Andromeda Galaxy. Stars yes, including Pleiades, and M110, M31's neighbor. I still do not understand that. M31 does not entirely fit in the FOV of my C8 even with the 0.63FF/FR, so perhaps that's it?
So the workflow that usually worked was (after connecting the mount to BYN within the program)
1. Enter target in CDC and Slew to it.
2. In Advanced Mode settings in the lower right of BYN, click the arrow next to the dropdown that lists the planetarium program, in my case CdC. This acquired the RA/DEC as well as the object name.
3.The ASTAP path had already been selected and the program location listed in "ASTAP executable " location, so next step was to tap "Center"
Usually after 1 or 2 quick circuits of the 3 tries listed got the image centered within the 100 pixels listed, although never for Andromeda, M 31
If it is useful the objects I intended to solve for in the event they are not listed in the log are as follows together with the times:
21:01 Capella - solved OK
21:11 M31 - did not locate object
21:25 NGC 1432 - solved OK
21:32 M 31 again - not located
21:38 M 110 solved OK then I took lots of Lights, Darks etc.
So that's it. Relieved I actually got plate solving to work. Thank you BYN!
logfile-[20201119-20h57m19s519]-[7556]-2020-11-19.txt
Nov 20
6
Nov 21
admin 2 posts
acatalano 5 posts
Nov 20 2020
Nov 21 2020
1 post
acatalano
So I received several replies from han.k the developer of ASTAP. In one message he mentioned that the latest version, 0.9.452 has improved features that may be relevant to this issue. My question has
6 answers to this question
