Ron Hillstromb
First - I know that BYE is designed and programmed for nighttime , long exposure Astrophotography. I find it easy to use and feature filled. I have been a user since it was early Version 2.XX.
Second - I appreciate the effort the Design and Programming team put into making it useable for photographing the 2017 Eclipse. A lot of effort was put into it and I used it with excellent results. I even bought a second copy of BYE so I could use two cameras at the same time on separate computers with USB shutter triggering. I could not synchronize the setup to take the photos at the exact same time of fast enough.
I am preparing for the 2023 Annular Eclipse and the 2024 Total Eclipse. I have built serial cables for shutter control and tested them using two cameras as Master and Slave. I have stepped out of bounds a little by using a single serial cable and a Y cable to trigger two cameras in this configuration. In tests it works fine in single frame use with synchronized operation but when I use the setup while taking Exposure bracketing shots with 3 shots there is a problem. More often than not all shots in the bracketing sequence do not complete in one or both cameras.
My requested feature, if possible:
I would like the ability to set the time the shutter is open or the serial cable holds the contact in milliseconds, 1 to 999 ms would be great but steps of 5 or 10 ms in the 1 to 999 ms would be acceptable.
Additional information:
I also own Eclipse Orchestrator which has this feature but with my camera setup, controls them one at a time in sequence I have used the adjustment to be able to use bracketed exposures but only with one camera at a time and not synchronized. I will exploring this option further in time.
I plan to use more than two cameras using the same serial cable and taking as many as 7 bracketed exposures with BYE, if possible.
There should be plenty of time to consider this and implementing, if possible
Ron
Sep 16
Aug 22
Sep 14
Ron Hillstromb 2 posts
astroman133 1 post
Sep 16 2019
1 post
Aug 22 2019
1 post
Sep 14 2019
1 post
