Ascom dithering question
cuivenion
Hi, I'm trying to dither using Ascom in Backyard EOS. when I start the imaging run the log shows 'dithering cancelled-mount not found' after the first image. I am running a HEQ5 via EQMOD and the mount is connected to the laptop and working fine. Gotos and tracking are fine. I have Ascom selected in the BYEOS settings, I'm at a bit of loss.
  • Answers 4
With the Premium version of BYE the top of the BYE main window contains controls for controlling ASCOM devices (telescope, focuser, filter wheel).
Select the telescope, click on the gear button to launch the ASCOM Telescope Chooser to allow you to choose the telescope driver. Change the Properties as needed and click OK. Then click on the telescope checkmark button to connect BYE to your telescope. Then ASCOM dithering should work.
