DoctorJack
I have BYE and use a Canon 5DMkiii. BYE is on a Windows 11 laptop. When I initiate a capture plan, it does fine, until the end. Once it reaches the total number of exposures, it starts again, from zero. To stop this, I abort the capture and delete the aborted pictures.
Am I doing anything wrong?
Mar 20
astroman133 2 posts
DoctorJack 2 posts
Mar 20 2023
astroman133
From your description of the behavior is sounds as though you may have accidentally pressed the Loop button. Its purpose is to cause the capture plan to repeat until aborted. This is briefly described
DoctorJack
Thanks, Rick. Will check both page 47 and my settings!
astroman133
When you restart BYE, the Loop button(s) should be off, so just make sure that you don't accidentally click on it.
3 answers to this question
