Bill.Richards
I'm using PHD2 with a ZWO ASI120MM-S guide scope and camera (~6.5 arc-sec/pixel) to auto-guide my CEM40 mount. I have a Canon EOS 6DII and normally use lenses in the 135-600 mm range (so 2-9 arc-sec/pixel). I use BYE to control the imaging session. I'd like to enable dithering but have a few NOOB questions:
1) If I'm using the 600 mm lens (2 arc-sec/pixel), will the default dithering settings be adequate or would I need to increase the aggressiveness?
2) What if I'm using a 135mm lens (9 arc-sec/pixel)? In that case, the guide scope will have a higher resolution than the camera. Would I then need to use the multiplier parameter in PHD2 to increase the dithering even more?
Oct 10
Oct 9
s3igell 1 post
Bill.Richards 2 posts
Oct 10 2020
Oct 9 2020
1 post
