CygnusX-1
I upgraded to 3.1.18, everything seemed to install correctly on the pc. The program starts in night vision mode and when I click connect a box opens up asking me to select my camera driver but the box is empty. There are are no driver options listed, no way to connect the camera and when I click on settings the following message pops up: "Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit the application will close immediately." "Object referenced not set to an instance of an object."
I attached a copy of the details provided along with the last log file.
I have been using previous versions BYE on the same PC since June 2016 without encountering any prior issues. Anyone have any suggestions?
Document.rtf logfile-[20191222-14h27m35s826]-[13804]-2019-12-22.txt
Dec 29
10
Dec 22
5
Dec 23
Dec 30
admin 9 posts
antonnetti 4 posts
CygnusX-1 3 posts
mike@astrospider.com 2 posts
Dec 29 2019
Dec 22 2019
Dec 23 2019
Dec 30 2019
1 post
antonnetti
Sure : as your software installs itself by default in the directory "BackyardEOSv3.1", I renamed the current folder to "BackyardEOSv3.1_old" and I install the new one. Thanks.
17 answers to this question
