Sequence repeats
willcarney
Last night I had several sequence of shots that repeated automatically after the first set finished.  I would select 10 shots.  It would do all 10 only to start another 10 shots without me hitting the start sequence.  I would have to abort each time.  Happened three separate times.  I was using a Nikon lens all night but had the lens set to manual focus and VR off.  No memory card in camera.  It did take the shots fine but just would not stop the shooting sequence.
BackyardEOS-log4net.txt
logfile-[20140831-22h09m08s233]-[42880]-2014-08-31.txt
logfile-[20140831-22h09m17s841]-backgroundworker-[22396]-2014-08-31.txt
  • Answers 1
Hi Will,
You had the "LOOP" button enabled.  This is what that features does... it loops your capture plan until you abort :)
