kalasinman
I use BYN with a D5100 and my laptop. I have the Shoestring shutter cable. I have been unable to get a clean startup of BYN. If I try to start the camera first, the camera won't be recognized by the laptop with the cables connected. If I start BYN, then turn on the camera BYN fails to link to camera giving USB hub message. I do use a new, mid level hub I purchased for this as well as all new cables. I need the hub because I have 2 USB ports on the laptop and one is needed for the mouse, one for the camera and one for the shutter controller. Leaving BYN running, I unplug the hub, and plug it back in. This usually causes the USB hub drver to load, and most of the time a driver for the D5100 as well. Sometimes this cycle must be repeated. Once the icon for the camera shows on the laptop, I select "connect to camera" this is usually successful, although I sometimes have to close BYN and open it again before camera will connect. BYN indicates Nikon drivers are loaded at startup, so why can't I connect immediately? This can be frustrating. I realize it's probably me, but whatever it takes. Thanks
