connection problem
paherrgon
  • Answers 1
Peter,
What version of BYE do you have?
Is your problem a connection problem or a LiveView problem? You said that it cannot connect, but you must be connected in order to change from Imaging to Frame & Focus.
If you are having a connection problem then be sure that you have the latest version of BYE. The 6D Mk II is only supported in 3.1.14 and later.
If you have the LiveView Autofocus in the camera's menus  set to Face+Tracking, you should try changing the setting.
