Frame & Focus Button not responsive
bjaffa
I am having an issues when I try to select Frame & Focus mode.
BackYardEOS version 3.1.9 (or 8) does seem to select the mode.
It use to work with an 3.0.x version. I have a canon 3ti.
Sometimes it will quickly change to Frame & Focus mode (using mouse) but then
switch back to Imaging mode. So I am unable to focus my setup.
Thanks for any help.
  • Answers 4
You are correct, I did have live view disabled on the camera.
I did not think to check the camera. I did not know it prevented me
from getting into the frame focus mode. But it makes sense.
Thank you for your help on my stupid mistake.
Thank you very much!!!!!!! :) ,
Brent
Thanks for the log file.
Looks like you have disabled Live View on your camera.
2017-04-06 12:12:22,921 [Main] DEBUG - ButtonPlus_MouseClick(btnFrameFocus = 'Frame & Focus')
2017-04-06 12:12:22,954 [Main] INFO - Camera action fired: 'LiveviewStart'
2017-04-06 12:12:22,959 [Main] INFO - Running (log): EDSDK.EdsGetPropertyData(CameraRef, BatteryLevel(8), 0, size(4), intPtr)
2017-04-06 12:12:22,963 [Main] INFO - Success: EDSDK.EdsGetPropertyData(CameraRef, BatteryLevel(8), 0, size(4), intPtr)
2017-04-06 12:12:22,965 [Main] INFO - Running (log): EDSDK.EdsSetPropertyData(this.mCameraRef, EDSDK.PropID_Evf_OutputDevice, 0, 4), (uint)Canon.OutputDeviceENUM.EvfOutputDevice_PC)
2017-04-06 12:12:22,988 [Main] DEBUG - BUSY try #1
2017-04-06 12:12:23,340 [Main] DEBUG - BUSY try #2
2017-04-06 12:12:23,690 [Main] DEBUG - BUSY try #3
2017-04-06 12:12:24,042 [Main] DEBUG - BUSY try #4
To confirm this, disconnect the camera from the computer and try to activate live from using the camera menu/buttons only.
