Ascom Baader Steeltrack Focuser stops after one click
docgvg
Hi,
I installed recently the new baader steeltrack focuser. I can use it with the software from baader, but if i try to use it within BackYeos after one click (say + 500) the focuser stops. When i continu clicking...i have to restart everything.
What am i doing Wrong.
Tx
Guido
  • Answers 2
Thanks for the logfile.
You ASCOM driver is trowing an error.  This is nothing I can do, the bug/error is coming from the ASCOM driver itself.
2016-03-29 08: 57: 12.860 [5] ERROR - A device attached to the system is not working.
2016-03-29 08: 57: 12.860 [5] ERROR - at ASCOM.DriverAccess.MemberFactory.CallMember (Int32 member code, String membername, Type [] parameter types, Object [] parms) in c: \ ASCOM Build \ export \ ASCOM .DriverAccess \ MemberFactory.cs: line 369
   at ASCOM.DriverAccess.Focuser.set_TempComp (Boolean value) in c: \ ASCOM Build \ export \ ASCOM.DriverAccess \ Focuser.cs: line 178
Does the software from Baader use the ASCOM driver?  Can you use the ASCOM driver with other software?
