How-to control your ASCOM Focuser
admin
A huge thank you to astroman133 for coming up with this simple yet effective set of instruction to control your ASCOM focuser in BackyardEOS and BackyardNIKON premium edition.
Quote
BYE does not "check focus periodically". It does allow you to adjust the focuser position, as you see fit, without touching the mount, telescope, or camera. It works with any focuser with an ASCOM driver, and the ASCOM Platform, installed.
You choose the driver to use by clicking on the "star" button to select "focuser" instead of other devices. Then you click on the "gear" button to select and configure the driver. Once that is done, you click the "checkmark" button to connect BYE to the focuser. Once you are connected, the chevron buttons are used to move the focuser in and out.
When on the Frame and Focus panel, BYE shows the measured diameter of a star in the centre of the zoom box. If you adjust the focuser while viewing a LiveView image of the star, you can see the size of the star change in near real time. Keep making changes to minimize the star's FWHM or HFD. Once satisfied, you can return to imaging.
The downside to the current implementation is that you must cancel a capture plan to switch from Imaging to F&F. Then, after focusing, you need to return to imaging and restart the capture plan.
When finished, you just disconnect the focuser and the camera and shut BYE down.
I hope this helps.
astroman133
Original post is below
  • Answers 0
0 answers to this question
There have been no answers to this question yet
