Will BYN connect to a D5300 via wifi?
outlier
  • Answers 1
BYN uses the Nikon SDK (Software Development Kit) to manage the low-level communications with the camera. BYN does not know or care how that is done. If the SDK supports WiFi, then what you want to do should be possible. You may need to pair the camera with the computer. The following link describes how to do that:
https://onlinemanual.nikonimglib.com/z5/en/10_establishing_wireless_connections_02.html
Even if that works, you may want to use the wired USB connection instead. The wired connection is faster and more reliable. Also if you go to large star parties, you may be prevented from using WiFi for control of your equipment.
