Atik 2'' Electronic Filter Wheel EFW2 [ATK-0087]
ATK-0087
$536.40 CAD $825.23 CAD
Atik Cameras:This product is the Atik 2" Filter size Electronic Filter Wheel.
This new Filter Wheel employs exchangeable filter disks, allowing for multiple combinations, and has large 54 mm openings on both sides. With these features, the EFW2 can easily support sensors up to full frame (35 mm) format. The EFW2 also features a slick design, with a slim and lightweight profile. For example, the distance between any Atik camera and the wheel itself is 0 mm, while still maintaining the possibility of rotating the camera to any desired position. Total extra backfocus needed will be only 22 mm.
For the Atik Electronic Filter Wheel product line, the filter disk size options include 5 x 50.8 mm, 5 x 2" mounted, 7 x 36 mm, and 9 x 1.25" mounted.
As for sofware, the EFW2 has an ASCOM compliant driver, so that ANT compliant software can control it. Additionally, the EFW2 can be controlled by Atik's Artemis Capture software, for easy, simple, efficient operation.
Included With The Atik Electronic Filter Wheel (EFW2) In The Box:
Filter Wheel: EFW2 body with your choice of filter disk
2" adapter
Hex key kit
Screws, plastic washers, and o-rings (with specific disk options)
Control Cable: 3-meter long USB cable
Power: 1.8-meter long battery power connector
Interface: Mini USB type
Power: 12 VDC, 0.3 A (max)
Weight: approx. 500 gr
CD-ROM with drivers, software, and User's Manual (PDF)
Quickstart Guide (paper)
About Atik 2'' Electronic Filter Wheel EFW2 [ATK-0087]
2" adapter
Hex key kit
  • Model Number    ATK0087
  • Type of Filter Accessory    Filter Wheels
  • Filter Wheel - Number of Positions    Five (5)
  • Filter Wheel/Carousel Size    2"
